frkshow 0 Report post Posted June 22, 2010 hae guys just bought a e30 320i coupe auto and today it died on me. turn the key to the ON position and only the battery light on the dash lights ups and nothing else. not even the check light. i checked all the fuses and none of them are blown. when you try start it the car wont crank or turn over. HELP!! PLEASE Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted June 22, 2010 (edited) Check your starter motor /alternator connections/earth straps.You sure the battery has FULL charge? Edited June 22, 2010 by 1rotty Quote Share this post Link to post Share on other sites
frkshow 0 Report post Posted June 22, 2010 Check your starter motor /alternator connections/earth straps.You sure the battery has FULL charge? yea checked all that. the car was running and i turned it off and went to start it again and thats what happened. the battery does have full charge. the red circled bits are the lights that dont come on. when i turn the key on Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 22, 2010 does the car have a alarm fitted?? Quote Share this post Link to post Share on other sites
frkshow 0 Report post Posted June 22, 2010 does the car have a alarm fitted?? yea it does but its all unplugged i dnt no why. is their a fuse for the cluster that could be blown? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 22, 2010 (edited) +1 to 1rotty. Does it make a "click" when you turn the key? as if the solenoid was engaging. Did you check the earth strap on the passenger side of the engine, it's attached to the sump near the oil level sensor. Edited June 22, 2010 by antil33t Quote Share this post Link to post Share on other sites
