Guest BimmerzE36
Cant find an Aux Input
Guest BimmerzE36
I have this SONY CDX-F7710 deck, it has a CD changer in the back; Had it installed a while ago and I lost the manual, Recently I wanted to connect my Ipod and then a Phone but I cant seem to find any AUX inputs :wacko: Did a lot of google and they all say it should have an AUX input ....
Anybody here got any experience with this Sony stuff; Point me to the right direction? . Do you know where exactly is the AUX port on it?
Edited by BimmerzE36
it's probably like mine and has no AUX but a line-in at the back of the unit.
i have an rca to 3.5mm jack going from the unit into my glove box. I had to change 'CD changer' mode, which was default to 'line in' inside of the heads units menu.
have you checked the back for two RCA inputs?
e: far too slow
Edited by Wervie67
Guest BimmerzE36
e: far too slow
no havent checked the back yet.... maybe I'll give it a try....but can any one confrim if this unit has any AUX support ?
Guest BimmerzE36
I managed to remove it and I think I found what seems to be a blue input, should be the AUX in, but I think I damaged my AC vents in the process :(
Guest BimmerzE36
yea, I found that, but then I'd have to unhook my CD Changer in the back.. :(. I'd rather keep it for now and maybe buy a better deck with the USB and AUX features later on... Thanks guys..
FYI may want to get another sony headunit that way you dont have to rewire it in theory, check it has the same plug tho
Guest BimmerzE36
True True! See I didnt think of that... should all good from now, thanks mate.
