Guest BimmerzE36 Report post Posted July 3, 2010 I am trying to find a sandwich plate adapter that'd sit between my e36's filter , housing and the cap or such. I'm in the process of finish installing some gauges I did last month, and I need the oil temp gauge sorted. The sender unit has to be mounted, but I just cant find the proper solution or the proper sandwich plate, (being that regular ones wont work since our cars have oil filter is inside the engine bay) Anyone got a solution to resolve this ? For those who are not aware of the filter housing, its next to your engine actually Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 3, 2010 You would have to remove the oil filter remote housing drill and tap the correct thread in an appropriate place in the housing on the feed side to the oil filter. M52 housings have provision for this. I'd have to check M42/M44 housings to check if there is provision.. but I'm pretty sure there isn't. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted July 3, 2010 Quote Share this post Link to post Share on other sites
Guest BimmerzE36 Report post Posted July 4, 2010 Where did you get that , Custom engineered? Now I think that would work just fine wont it ? Quote Share this post Link to post Share on other sites
Guest BimmerzE36 Report post Posted July 4, 2010 You would have to remove the oil filter remote housing drill and tap the correct thread in an appropriate place in the housing on the feed side to the oil filter. M52 housings have provision for this. I'd have to check M42/M44 housings to check if there is provision.. but I'm pretty sure there isn't. Hey mate, I would drill a hole on the top cap(not sure if that's even right, is it?) but then again if I can go with out making any holes and just a sandwich plate does my trick then life would be much easier... what do you reckon? Quote Share this post Link to post Share on other sites
