dubman 39 Report post Posted July 10, 2010 My e30 pulls to the right when steering wheel is straight. I didnt change the tie rod or twist it ( maybe the accidental 1/2 turn ), but after i put the left strut back in, the car pulls to the right. I changed the lower control arm, all the joints and bushes are in good condition. Its also not bent. Everything is torqued back to the correct figues. Going into the alignment shop monday, but no idea why its pulling to the right. Any ideas? Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted July 10, 2010 so you have changed the lower control arm?? theres the problem and the wheel alignment should fix it Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted July 10, 2010 If you moved/changed/replaced any part of the front suspension then an alignment should be top of the list. Also what did you do to the strut as that also could have a bearing on what could be wrong. Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted July 10, 2010 thanks alot guys, im just a paranoid person when it comes to cars, safety 1st. I just thought why would the alignment be out of place when i replaced with exact same part. Alignment Monday mornin'. Quote Share this post Link to post Share on other sites
