michaelstuart 0 Report post Posted July 20, 2010 Hi. My 1990 E32 735il keeps displaying the coolant level warning message when I turn it off, but the level seems to be completely fine. When I am driving the car the water temperature needle sits right in the middle of the gauge and doesn't get any hotter. Is this a common problem? I know that false tail and side light warnings are. Any help would be much appreciated. Michael Stuart Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted July 20, 2010 Hi Michael, welcolme to the site. Is the coolant level definitely above the level sensor? If so - a sensor/wiring/connection problem Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted July 20, 2010 The sensor is probably at fault. Especially if it's one of those floating type ones, can fill with coolant and sink, giving a false reading. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted July 20, 2010 probably a sensor. disconnect and short the terminals if your cheap, get a new sensor if your not. if your cheap dont forget to keep an eye on the level like the olden days Quote Share this post Link to post Share on other sites
michaelstuart 0 Report post Posted July 20, 2010 (edited) Thanks heaps. The coolant level is at the mark on the reservoir and the level doesn't seem to be decreasing, nor is the car overheating. How do I find out if the sensor is at fault or if it is an electrical problem? Edited July 21, 2010 by michaelstuart Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted July 21, 2010 as i said, disconnect the plug and short the terminals on it and then turn the car to on and see if the dash/checkpanel light is on after starting the car. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted July 21, 2010 or as mike said, if it's filled with water it will be quite obvious once you remove it and have a look. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted July 22, 2010 most likely the sensor, give me we have some in stock cheers Jon JK Southern Euro Quote Share this post Link to post Share on other sites
