allan
Water leak
Noticed some water on the garage floor and tracked it down to the temperature sender unit. Upon removing it I found it has only got one small "O" ring to seal it off. Does anyone know can the O ring be replaced seperately or is it a whole new sender unit No 4?.
http://www.realoem.com/bmw/showparts.do?mo...hg=11&fg=35
Thanks for any help
Allan, Haven't done one but picture shows no breakdown of sensor/ seal so from that - obviously not available from stealers.
If the seal comes off - can it matched with a generic one - eg - is it a typical round section O ring?
If so - you should be able to get another from Engineers Supplies or similar
