oscar90 0 Report post Posted July 26, 2010 Hey Guys having some trouble with a car Went to start up the E36 320i (Manual if it matters) as it sat and sat for months then the battery went dead... so didnt want the new battery to die... it hasnt been driven in a couple of months either.. so i started up from dead cold and its pulsing like a retarded Rotor The car was condensating inside alot as it sat closed up for a good 2 months so maybe moisture has got somewhere or the ECU is in learn or limp mode since the batt went dead flat and has been changed? Or somethings buggered or stuck? idle valve? Anyway the video will explain what I mean, im not touching the accelorator at all in the Video! It drives fine until you put the clutch in then it does the weird hunting and pulsing rubbish again 'till its back in gear No warnings lights or faults showing on the dash or OBC Thanks in Advance! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 26, 2010 Get it scanned first... could be a number of things causing this. Air leaks, sensors or crankcase ventilator valve Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted July 26, 2010 Thanks Glenn It ran Fine before the battery went dead and it got parked up BTW Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted July 26, 2010 yes to the scan, but pull the cover off in the engine bay that Hides the Ecu, check for moisture around the ECU for corrosion comon issue, we have some in stock call me if you need a better explanation Jon 04 3801089 Quote Share this post Link to post Share on other sites
