_Matt_ 42 Report post Posted July 31, 2010 so removing the bolts on the side panels isn't a problem but the two bolts at the front of the car that are attached to what i assume are shock absorbers, i can't get too. small spanner maybe? and also...you have to tension the bolts correctly, yes? is there a way i can do that with standard tools? the reason for removing the bumper is to get to a rust spot so i can clean it up and re-spray it. cheers team Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted July 31, 2010 17mm socket with 30cm extension come up from underneth through a hole in the chaisis rails Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted July 31, 2010 17mm socket with 30cm extension come up from underneth through a hole in the chaisis rails wicked mate, will give that a go. thanks a lot. Quote Share this post Link to post Share on other sites
