thorburn 123 Report post Posted August 7, 2010 Brembo calipers from Brembo GT kit that fit 320x28mm rotors Bolt straight on to e36 or 46 (not including m3's) Can fit under a 16' wheel Comes with old original cross drilled rotor, pads, calipers, and mounts http://www.brembo.com/CatalogoHPGT/DetailP...&idLingua=1 http://www.trademe.co.nz/Browse/Listing.as...751&ed=true Schnitzer type 1 wheels 16x8 et35 5x120 Tyres are yokohama 205/55 DNA Grandprix. All have not a lot of tread http://www.trademe.co.nz/Browse/Listing.as...067&ed=true Quote Share this post Link to post Share on other sites
central3 31 Report post Posted August 7, 2010 The rotors on the front of my E46 330i are 325 diameter - will the calipers suit do you know? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted August 7, 2010 It is about the height of the rotor is about 60mm. I'll get some accurate measurements when I find a ruler They might be able to be shimmed up to fit Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted August 8, 2010 Dimensions: http://www.brembo.com/CatalogoHPGT/DetailP...ni/09558520.pdf Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted August 11, 2010 Bump cause it needs to go Quote Share this post Link to post Share on other sites
Nu-Del 0 Report post Posted August 16, 2010 What sorta coin are you after for the brakes? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted August 16, 2010 they have already sold on trademe Quote Share this post Link to post Share on other sites
