htra024 0 Report post Posted August 7, 2010 (edited) Hi, I changed rear break pads and sensor for my E46 328 Ci 2000 but the break waring light on my dash still on. I wonder how to reset the light? Thanks K Edited August 10, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 7, 2010 Did you check the fronts as well ?... the front sensor may have been triggered. Some of the cars will only reset by doing a service reset with a scanner. Quote Share this post Link to post Share on other sites
htra024 0 Report post Posted August 7, 2010 I have not checked yet however I have been told by BMWorkshop that front pads are not too low hence I think it does not affect to the front sensor at all. Any chances the sensor triggle itself? Thanks K Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted August 7, 2010 From my understanding the brake sensors are not a trigger in the sense you may be thinking of. They are a piece of wire and when it breaks it creates the open circuit and this is what registers the fault. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 7, 2010 From my understanding the brake sensors are not a trigger in the sense you may be thinking of. They are a piece of wire and when it breaks it creates the open circuit and this is what registers the fault. Correct.. i used the words triggered as in turning the light on Quote Share this post Link to post Share on other sites
htra024 0 Report post Posted August 10, 2010 The guy reseted my e46 service kms warning clock through the 20 pin connector by the reset tool. The clock now show 25,000kms couting down. Its great moreover, the reset also clear the break warning light at the same time too. So i think the break warning light need to be reseted after replacing the sensor. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 10, 2010 The guy reseted my e46 service kms warning clock through the 20 pin connector by the reset tool. The clock now show 25,000kms couting down. Its great moreover, the reset also clear the break warning light at the same time too. So i think the break warning light need to be reseted after replacing the sensor. What did I say ^^^^up there ?? Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted August 10, 2010 Break = to ruin something, when something fails or to divide something Brake = a devise used to slow progress or decelerate. Quote Share this post Link to post Share on other sites
htra024 0 Report post Posted August 10, 2010 Im sorry for my bad English so shy lol. Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted August 17, 2010 If we are doing spell checks: Brake = a device used to slow progress or decelerate. Fixed Quote Share this post Link to post Share on other sites
