keen 6 Report post Posted August 8, 2010 Is it possible to change the japanese sat nav to work in NZ? The mini has it fitted and I was wondering if it can be changed to work in the NZ? Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 8, 2010 Yep, sure can. PM me Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted August 11, 2010 Is it possible to change the japanese sat nav to work in NZ? The mini has it fitted and I was wondering if it can be changed to work in the NZ? Non-iDrive Mini = EASY iDrive Mini = HARD Both can be done. After conversion, you have a standard system identical to a NZ-New mini NOTE: the Japanese radio in your Japanese Mini can also be reprogrammed to Euro mode, you do NOT need a band expander Quote Share this post Link to post Share on other sites
Sandybs 0 Report post Posted September 7, 2010 Non-iDrive Mini = EASY iDrive Mini = HARD Both can be done. After conversion, you have a standard system identical to a NZ-New mini NOTE: the Japanese radio in your Japanese Mini can also be reprogrammed to Euro mode, you do NOT need a band expander Is this applicable generally to Japanese nav units.is it a software change then a new data disk ? I am considering getting one going in a 2005 MB E Class. Is there somebody who does it in Wellington> Quote Share this post Link to post Share on other sites
Sandybs 0 Report post Posted September 7, 2010 Yep, sure can. PM me Is this applicable generally to Japanese nav units. is it a software change then a new data disk ? I am considering getting one going in a 2005 MB E Class. Is there somebody who does it in Wellington> Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted September 7, 2010 Is this applicable generally to Japanese nav units. is it a software change then a new data disk ? I am considering getting one going in a 2005 MB E Class. Is there somebody who does it in Wellington> The comments are specific to BMW nav systems in BMW, supplied to you from BMW fans who own and drive BMWs and know BMWs inside out. For Mercedes information, please ask the Mercedes specialists in the Mercedes forums. Every car manufacturer does things differently - a Mercedes is not a BMW, just like a Windows Smartphone is not an iPhone. Quote Share this post Link to post Share on other sites
