M325is
Where is my dash earth?
Need to find my dash earth to check it, apparently I should ask before looking as they are usually in stupid place...
Anyone know?
87 E30
Cheers
Shelley.
Hi Shelley, they're above the glovebox. Just undo the 2 straps holding the glovebox up and let it drop, then remove the cover panel above the gbox, the earth should be in front of you then, 10mm nut holding a bunch of brown wires.
