2jze34 0 Report post Posted August 28, 2010 Im trying to locate the plastic valve pieces/unit that screw on the back end of the intake chamber and also conect to the rocker cover. im not sure what they are commonly called but the drivers side one is leaking and the car is running like sh&% ive tried a new gasket and o ring but still no result. ive anyone even thinks they maybe able to help please advise. thanks karl Quote Share this post Link to post Share on other sites
*Glenn* 855 Report post Posted August 28, 2010 You won't get those 2nd hand, and I wouldn't use 2nd hand ones anyway. They are the crankcase ventilator valves... I can help ordering new ones for you, they will probably be X Germany. Ring me tomorrow if you like...I'll need your chassis# Quote Share this post Link to post Share on other sites
