alcarhole
E36 REVERSE LIGHTS NOT GOING
I had that problem except with the brake lights in the E36 ...
I turned out that water sometimes leaks into the lights bit and rusts the connections ... i had to give to connections a real good clean and it worked ok for a while ... best thing to do was to change the actual light bulb holder ...
Auto or manual???
Pull up the centre console and check the wiring if you can, also, read that thread on owning an E36 in it's entireity, it'll probably have something on it as it's quite thorough.
