matt45 1 Report post Posted August 30, 2010 Hi all, So after the downpour at the weekend I have notice that there is water in the area of the boot where the cd changer is mounted. Car is a 96 e36 coupe with sunroof. Have searched around but everyone else seems to have issues around the firewall. Are there sunroof drains that go to the rear? The boot lid seal seems ok and the car was parked facing up hill so should have drained away from boot seal ok anyway. Any ideas appreciated. Thanks in advance! Quote Share this post Link to post Share on other sites
Smac01 12 Report post Posted August 30, 2010 I'm sure someone else will have more of an idea, but it might be leaking thru the seals around the tail lights? Hi all, So after the downpour at the weekend I have notice that there is water in the area of the boot where the cd changer is mounted. Car is a 96 e36 coupe with sunroof. Have searched around but everyone else seems to have issues around the firewall. Are there sunroof drains that go to the rear? The boot lid seal seems ok and the car was parked facing up hill so should have drained away from boot seal ok anyway. Any ideas appreciated. Thanks in advance! Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted August 30, 2010 Can only think of the boot seals. They can 'look alright' but still leak - next time this happens again have a close look at the seal and see if the inner part of it is wet. Or you can test it out with a hose. Quote Share this post Link to post Share on other sites
5amchris 45 Report post Posted August 30, 2010 do like that power saving ad dude does. but lock yourself in the boot and use a bright light or something and see if someone outside can see any leaks of light. Quote Share this post Link to post Share on other sites
master garion 1 Report post Posted August 30, 2010 Hi all, So after the downpour at the weekend I have notice that there is water in the area of the boot where the cd changer is mounted. Car is a 96 e36 coupe with sunroof. Have searched around but everyone else seems to have issues around the firewall. Are there sunroof drains that go to the rear? The boot lid seal seems ok and the car was parked facing up hill so should have drained away from boot seal ok anyway. Any ideas appreciated. Thanks in advance! I have the same problem in my E36 sedan. I think someone mentioned on here that tail light seals are a common cause. Anyone know where I can source some cheaply locally? do like that power saving ad dude does. but lock yourself in the boot and use a bright light or something and see if someone outside can see any leaks of light. lol genius Quote Share this post Link to post Share on other sites
jom 96 Report post Posted August 30, 2010 Hi all, So after the downpour at the weekend I have notice that there is water in the area of the boot where the cd changer is mounted. Car is a 96 e36 coupe with sunroof. Have searched around but everyone else seems to have issues around the firewall. Are there sunroof drains that go to the rear? The boot lid seal seems ok and the car was parked facing up hill so should have drained away from boot seal ok anyway. Any ideas appreciated. Thanks in advance! I had a problem like this on a Honda Accord, and it drove me nuts. I eventually realised the petrol filler aperture had been repaired without a sealant between it and the rear wing, and it only leaked when the water ran directly over it (parked at an angle, or at 100kph!). Worth a look. Jo Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted August 30, 2010 I have a similar problem which I haven't fixed yet but the problem for me is the tail-lights, the gasket seal is old so its letting water through. Quote Share this post Link to post Share on other sites
matt45 1 Report post Posted August 31, 2010 alright have ordered both taillight and boot seal so hopefully that will fix the problem! thanks, Quote Share this post Link to post Share on other sites
Heino 1 Report post Posted August 31, 2010 i had this problem and it was the petrol locking actuator which was broken and the water was going throught there (the pin which locks the flap) Quote Share this post Link to post Share on other sites
