jimbo01
Glue to reatatch the rear velour to the trim
I have bought a Black e38 rear sub woofer trim which has some of the cloth lifting off and I need to reatatch it. Is there a product that anyone has sucessfully used?
Thanks
Ados F2 in an aerosol can will work, as will the brush on type. Otherwise get the green can which is a gel version if you don't want any drips. Otherwise, any other contact adhesive will work. Make sure you apply to both sides and let the glue flash off before you stick them together.
Thanks - will try it
