cliffdunedin 8 Report post Posted October 5, 2010 Hey guys, a couple of weeks ago i posted about my bonnet not opening. i have tried some of the tricks from this thread, http://forums.bimmerforums.com/forum/showthread.php?t=959132 too no avail. Has anyone else had this same issue, and how did you get it sorted without masacreing the front end of the car. cheers Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted October 6, 2010 Mr Google says Open like this Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted October 6, 2010 Get someone to try pulling it up at the same time as you pull the lever? Quote Share this post Link to post Share on other sites
Yamahoo 6 Report post Posted October 6, 2010 Had the same problem - The bonnet pins have slotted ends to take a flat bladed screwdriver. I managed to get a screwdriver up through the hole from underneath with the kidney grills out and just unwind the bonnet pin from the bonnet. Easy peasy, as I recall. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted October 6, 2010 Get someone to try pulling it up at the same time as you pull the lever? Thanks mate, tried that and got one side loose! Had the same problem - The bonnet pins have slotted ends to take a flat bladed screwdriver. I managed to get a screwdriver up through the hole from underneath with the kidney grills out and just unwind the bonnet pin from the bonnet. Easy peasy, as I recall. thanks will try that tomorrow...no wiper fluid and pollen everywhere is beginning to annoy me! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 6, 2010 Is it still stuck ?? Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted October 7, 2010 Yep got it sorted! I took the other boys advice and had someone pull the bonnet lever while i jiggled the bonnet, the left side popped up, but not the right! I then removed the right kidney grill and used a flat head screw driver to undo the bonnet pin and boom undone...put it all back together and then tried the bonnet a few times. Still don't understand how it got stuck in the first place though! Quote Share this post Link to post Share on other sites
