Forrest 35 Report post Posted October 20, 2010 Does it work? / Can it be done? / Anyone done it before? Cheers, Nathan Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted October 20, 2010 can be done. have it on my racecar, text me or i can come round and show u Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 20, 2010 Have done it on both of ours, just switched on the dash when needed. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted October 20, 2010 Cheers. Whats the easiest way to wire them up? Do I put a fuse in the circuit? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 20, 2010 I have a 20 amp fuse and a 30 amp switch, they draw a lot of current. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted October 20, 2010 Alright thanks Dave. So I assume it just has a power and a earth and I fuse the power wire with a switch in the middle? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 20, 2010 That's what I've done, works a treat. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted October 20, 2010 Awesome, thanks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted October 21, 2010 i have this set up in the twincam so it works but (in my case anyway) it was part of the aircon radiator thing and not seperate so i had to make a custom bracket to stop it flapping around. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 21, 2010 Yeah, used the same, but cut the aircon radiator from the support bracket and adapted the bracket and fan to go back on the original mounts. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted October 24, 2010 heya Nathan common mod, just cut the core out of the radiator and leave the surrounding bracket. It will make it easier to mount the fan into the shell of the vehicle, then fuse, relay and wire it up to use the existing switch on the dash , so that it looks in place cheers Jon Quote Share this post Link to post Share on other sites
