s.o.s.nz
FS: $50reserve ASA Revolution 17x8 rims (bbs mesh look)
As above, 1 is damaged, unsure if it is repairable.
FYI
I picked up a cheap pair of rims a few years back and one had similar damage.
Sent to Warren at RIMRITE in Palmerston North, was $160 and came back like new.
FYI
Could be a great bargain for someone out there...
I couldnt find it on the rim but im pretty sure theyre 3.5mm offset, if that makes sense
They dont look like that low of an offset, maybe 35 instead of 3.5?
Could also be keen if offset is right
To fit a holden or E36 the offset will be ~35 (mm)
The Monaro R8 rims i have on the Tow Pig are 48, don't know what 35 would look like.
Yes sorry I think the new Holdens may have changed the offset
These are 35mm
They were on my 98 M3 E36
Thanks
Edited by s.o.s.nz
