camera doctor 25 Report post Posted November 4, 2010 Took our caravan for a WOF yesterday, and the inspector suggested that I get under it and wirebrush and treat the chassis / drawbar to stop the surface rust getting any worse. I have seen other forums and websites talking about POR 15 rust preventive paint, and wondered if anybody on here had experience with it ? It appears to dry superhard and is less likely to be effected by stones flicking up off the roads. Would I need to remove all the old paint first for example? or just wirebrush / wirewheel the worst of the rust and paint over ? Any experience / recommendation would be appreciated. Thanks Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted November 5, 2010 (edited) The instructions just say to wire-brush, treat with rust kill then rinse with water, allow to dry and paint with POR-15. (edit - its still paint, so won't stick to unclean or overly smooth surfaces) It does dry "hard" (its almost like ceramic), is easy to apply, is permanent on exposed skin (haha), and quite expensive compared to other options. I've used it before but probably not on anything that I can give a realistic view on whether it lives up to long term exposure to harsh conditions (like under a caravan). Edited November 5, 2010 by CamB Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted November 5, 2010 George (Espirt) has used it extensively on his lotus rebuild... It's not uv stable without a clear coat. They have a metal prep product and metal clean that would be recommended to use in conjunction with each other. You can buy starter kits. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 5, 2010 Im also interested in somthing that stand up to gravel. All my underseal is getting ripped off from gravel hitting it. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted November 5, 2010 I know a few people have used the tuffdeck spray on they cars for gravel Quote Share this post Link to post Share on other sites
