albert_84 0 Report post Posted November 10, 2010 Hi...Newbie here and it will be my first time to have a bmw.. ill be buying a 2000 BMW 318Ci on friday.. any tips or suggestions that i should be looking after? thank you Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 10, 2010 The best tip / advice I can give you is : Get a prepurchase inspection done by a Dealer or a BMW Independent Specialist.... no one else Quote Share this post Link to post Share on other sites
albert_84 0 Report post Posted November 10, 2010 hi glenn. thanks for that.. btw, do u have a shop? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 10, 2010 (edited) This is Glenn, and he's highly recommended, even if he doesn't say so himself. Botany Motor Worx Ltd. Corner Ormiston Rd & Te Irirangi Dr Botany South Auckland Ph: (09) 2722546 http://www.botanymotorworx.co.nz/index.html Edited November 10, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted November 11, 2010 Definitely get an inspection performed by a BMW dealer or specialist as they know what faults to look for in each model etc. as per Glenn's post. Also, from experience with E46 I'd be checking to make sure the windows all roll up and down right the way. And make sure the cupholders (if any) are functioning. (Not sure if in any E46 models they are the spring loaded ones that eject from the dash) Quote Share this post Link to post Share on other sites
Heino 1 Report post Posted November 11, 2010 (edited) Hi...Newbie here and it will be my first time to have a bmw.. ill be buying a 2000 BMW 318Ci on friday.. any tips or suggestions that i should be looking after? thank you i have the excact same car and i am loving it. Edited November 11, 2010 by Heino Quote Share this post Link to post Share on other sites
