george graves
e30 Interior light delay w/ auto dimming.
Just in time for the holidays. They made a killer present for yourself, or one of your buddies that helps you wrench.
I only have a limited number of these - I make them mostly for friends and gear heads here in the states.
Posted Image
delay times nonadjustable - they come preset to match the factory e90 specs.
Posted Image
It works just like newer BMW's, when you close your driver's door, it keeps the the lights on, and then slowly fades out over a period of about 30-45 seconds just like the new BMW's.
It has an added feature that when you turn the key, it dims down the light quicker, so that you can start driving with out glare. Anyone that had driven a newer BMW knows this feature. It adds a really cool lighting effect, and is very useful at times. Like when you need to read a map real quick.
- Plugs right in and replaces the stock relay
- Quality construction
- Installation only requires a Phillips head screw driver and a 8mm socket.
- Free USPS International shipping shipping
Posted Image
Here is a look inside the case.
Posted Image
Posted Image
$55 USD
Paypal - [email protected]
(USPS Priority International and FedEx shipping w/ insurance available on request)
Posted Image
Posted Image
- remove the drivers side bottom dash cover to gain access to the hood release cable bolts (8mm) and remove the bolts.
- Remove the speaker panel and the speaker.
- Remove the two screws that is just below the speaker opening and reach into the speaker cavity and pull the bracket out
- Remove relay, and plug in the new dimmer mod.
- button it back up and you are done.
Thanks! Bump
i have an e34 which alreaady has the delay and or off with key....any way to add the "dimming" feature only??
Is that installation for Left or Right Hand drive?
Both - except right hand drive models don't need to remove the hood cable IIRC.
Right hand drive e30's hood cables on the left hand side, correct?
Anyways - the realy it replaces is on the driver's side on all e30 weather it's right or left hand drive.
Edited by george graves
