J~~
Spring Change
Anybody know how to change the rear springs to a E36?
Planning to have a crack at it myself.
Very very easy. Release the hand brake first. Undo the shock bolt and then pry the spring out. It shouldn't take more than 10 minutes per side :)
Get someone to stand on the wheel hub if you can't pull the old springs out at first.
And undo both shock bolts, or you'll be fighting the sway bar (assuming you've got one).
