bezzal 1 Report post Posted December 8, 2010 My car has an airbag error on the dash. I understand the component that is causing the error, will show up on a scan, is this correct? I presume after the Scan and replacement of the component it will then require a reset, to remove the light from the dash? Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted December 8, 2010 My car has an airbag error on the dash. I understand the component that is causing the error, will show up on a scan, is this correct? I presume after the Scan and replacement of the component it will then require a reset, to remove the light from the dash? your excactly right.what part is faulty? have you changed it and now need someone to reset it. i know you can reset your service light on the dash with out plugging in a diagnostics machine but air bag i think you need a work shop. ill check my facts in a book a have but im pretty sure you need a visit to a work shop. Alot of workshops can do this for you as its very common software "OBD2 from memory" where abouts are you located i could recomend a place if you like. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 8, 2010 Can check it today for you if you like Quote Share this post Link to post Share on other sites
bezzal 1 Report post Posted December 9, 2010 Can check it today for you if you like Hi Glenn, sorry I wasn't online yesterday, that would be appreciated. How is your day looking today? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 9, 2010 Hi Glenn, sorry I wasn't online yesterday, that would be appreciated. How is your day looking today? Just call in...preferably this morning sometime Quote Share this post Link to post Share on other sites
bezzal 1 Report post Posted December 9, 2010 Just call in...preferably this morning sometime Thanks Glenn, great service and friendly advice as usual! Quote Share this post Link to post Share on other sites
