A518catcher
Different Differentials ??
Can the Diff Gurus tell me what on earth is going on with my Diff.
I purchased a 1989 nz new 520i, lovely car but i straight away noticed noise from the rear.
ive pulled out the Diff and sure enough its noisy, maybe a pinion shaft bearing.
heres the catch. :huh:
The tag says 4/45.
This is not a Diff that comes standard and some ones thrown it in.
The other point is that my speedo is way out. 130km/h at 2700 revs but only feels like 100km/h .
this diff only came out in a 318At i think,
From looking on the net the 4/45 is a bit rare and might be worth something.
either way i just want a quiet diff and a correct speedo for the wife.
Presuming you have a M20 E34 not a M50 Then:
According to the BMW ETK it will have a 4.45 Medium Case (Type 188) diff.
It is quite a rear ratio for Medium (type 188) diff, but unfortunately the E34 case won't fit into anything else except maybe E32's.
You can get a lower ratio diff from most 325 E30's & E36's and E28 5 er's.
But you will have to take the two (yours & the new lower ratio diff) to a Diff shop and the internals swapped over.
If you're sure your speedo is out of whack then either your wheel size is significantly smaller than the stock size or you have a faulty pickup.
If you're in the market for a new diff then I have a ratio & rpm vs speed graph spreadsheet you can use to determine what you ratio you want.
thanks for the info about the ratio graph, and i think your right, the pick up is stuffed.
but i think ill just go for the standard ratio for that model/year or get this one fixed.
all a learning curve
