Wom 0 Report post Posted December 25, 2010 Hi I'm having some slight issues with my heater / aircon A couple of days ago I went to go to a mates place and noticed there was no airflow coming from the vents I cranked up the speed and still nothing, I also tried the demister and still nothing All the lights show up on the control panel perfectly It doesn't matter whether I have the aircon on or off either (actually, any setting at all doesn't provide any air flow) Last night when I went out, it decided it was going to work again, so I thought hmmm maybe it just needed to be turned off and on like an IT guy would say to do with a PC issue lol But then when I left my mates place, it wasn't working again Lose wire maybe? Or something major? 1996 E36 323i coupe has the digital hvac control panel Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted December 25, 2010 Common fault with the e36's , I have done heaps of them of other people. Don't do them any more cause i don't have an e36 to test them on. Read up on this link and do it yourself if you are willing to. Its pretty easy. Visit My Website Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted December 25, 2010 choice, cheers for that link Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted December 25, 2010 Not sure if that is your problem. When it happened to mine, the display went dark and was like the unit was off/locked (no buttons did anything) Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted December 25, 2010 Could also be the final stage resistor. Quote Share this post Link to post Share on other sites
HELLBM 1696 Report post Posted December 25, 2010 Fan speed resistor the most likely issue. $80 @ Hellbm Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted December 27, 2010 http://forums.bimmerforums.com/forum/showthread.php?t=292522 same symptoms so will give you a call Ray to suss out the part would it be on the passenger side or the drivers side? (I'm guessing the one in the link is left-hand drive) Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted December 31, 2010 the culprit was ... the hedgehog-like resistor Quote Share this post Link to post Share on other sites
