Damo 23 Report post Posted January 16, 2011 (edited) Anyone got one lying around that they want to offload? thanks! Edited January 25, 2011 by Damo Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted January 17, 2011 What are the symtoms of the trans in the car? With 5HP30 it can sometimes be an easy fix. Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted January 17, 2011 What are the symtoms of the trans in the car? With 5HP30 it can sometimes be an easy fix.put into reverse and motor revs up slightly, but nothing after that. All forward gears fine - does that help? Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted January 17, 2011 (edited) Call and I will explain repair process. Requires a $7 part and some patience. Have heard of trans repair specialists charging a few thousand $ to sort the same problem. Edited January 17, 2011 by HELLBM Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted January 17, 2011 Call and I will explain repair process. Requires a $7 part and some patience. Have heard of trans repair specialists charging a few thousand $ to sort the same problem. Thanks greatly for the offer Ray - I will call you soon! Quote Share this post Link to post Share on other sites
Damo 23 Report post Posted January 25, 2011 In case the check ball repair does not work out - does anyone have one of these? Quote Share this post Link to post Share on other sites
dnkx 0 Report post Posted January 26, 2011 a mechanic friend of mine had one in wellington a few months ago, it was removed from the car, sent to hutt automatics (the local auto specialists) who stripped it, changed all of the worn parts costing 1400 (invoice should be available), around this time the customer decided they couldn't afford to fix the car so he was left holding the box... i will check with him tomorrow. if you pm me your phone number i will text you his contact details after i have spoken with him if you like... Quote Share this post Link to post Share on other sites
