byza213
e30 tech 2 kit
in the near future i am looking at picking up a kit if i can :unsure:
is it pretty easy fiting on ?
do the side skirts need to be modified being a wagon?
or would the for door kit be bolt on type stuff.
You'll need a bunch of clips and a drill to install.
If you don't get the clips with the main parts get them off pelicanparts, they're quite cheap.
4 door kit will fit a touring.
I put a genuine tech two on a touring a couple years ago. No difference with the touring compared to a four door except that the rear pod that screws to the wheel arch doesn't quite sit perfectly. Certainly not overly noticeable. Apart from drilling lots of holes in the lower sill along the sides, which would be the usual anyway, it was fine.
thanks guys will be looking at one in the near future if the guys still keeps it for me :D
out my range at the moment more saving up to do!
