Gotheschu 1 Report post Posted January 25, 2011 Spent all day Sunday working on the electrics of the car with Ray Chubb. Got everything working but today I've noticed that the passenger park light works fine but its headlight or high beam doesn't now.... Its not the bulb as I tried the bulb from the working light? Any ideas. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 25, 2011 Jack, Are you saying neither beam work or just high? If only high - sounds like no power to bulb - Check fuses for a start Quote Share this post Link to post Share on other sites
Gotheschu 1 Report post Posted January 25, 2011 Jack, Are you saying neither beam work or just high? If only high - sounds like no power to bulb - Check fuses for a start Ill try explain real in detail, as best I can.The far passenger side circular light only works on the first click of the little light controlling knob. When the knob is pulling up the whole way it turns off, same scenario with high beam. Fuses looked fine Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 25, 2011 Sooo, you have absolutely NO lights glowing (LHS) when headlights are turned on? And only park when on park position? If so - check for power at light wiring - if so - it will have lost it's earth Quote Share this post Link to post Share on other sites
Gotheschu 1 Report post Posted January 25, 2011 Sooo, you have absolutely NO lights glowing (LHS) when headlights are turned on? And only park when on park position? If so - check for power at light wiring - if so - it will have lost it's earth Will do. Auto sparky got it working fine after a while few days back so strange its gone again... Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted January 25, 2011 Check the wire connection between the headlight wire and the harness, also the plugs into the back of the headlight. If you've been pulling them out a lot they'll get loose and the connection will break, I know from experience Quote Share this post Link to post Share on other sites
Gotheschu 1 Report post Posted January 26, 2011 Check the wire connection between the headlight wire and the harness, also the plugs into the back of the headlight. If you've been pulling them out a lot they'll get loose and the connection will break, I know from experience I think thats if cause now I put the cap back on the park light doesn't work. Whats the cure? =) Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted January 26, 2011 I chopped up a spare harness and rewired hah, there's probably a simpler solution though. Check with a multimeter where the break is, strip the wire and reconnect perhaps?? Quote Share this post Link to post Share on other sites
