Tristan 338 Report post Posted January 28, 2011 can it be made to fit and is this a costly process? Quote Share this post Link to post Share on other sites
Sammy J 1 Report post Posted January 28, 2011 yep, any machine shop should be able to do it, not costly at all. had some done not long ago for $20 cash a wheel Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 29, 2011 If 5 series E34 wheels have a CB of 72.5 and my E39 is CB 74.1 then they can be made to fit, given that the offset is correct which I'm fairly sure it should be ? Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted January 29, 2011 Correct. Offset will be more or less the same, but you will need a machine shop to make the center bore bigger. Quote Share this post Link to post Share on other sites
Jeddy 0 Report post Posted January 29, 2011 Wait, wont the wheels need to have 1.6mm bored out of the centre bore? surely thats reasonably expensive. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 29, 2011 just make sure they know what they are doing....the hole MUST be hubcentric Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted January 29, 2011 Who would I get to do this? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted January 29, 2011 Who would I get to do this?as above, iam sure the Ak guys will point to the right guys Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted January 30, 2011 I know Brugar Engineering redrill wheels but I'm not sure if they will increase the bore size. Give them a call and ask, also try Arrow Wheels Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted January 30, 2011 I know Brugar Engineering redrill wheels but I'm not sure if they will increase the bore size. Give them a call and ask, also try Arrow WheelsBrugar will do it, they did mine in Nov for $103.00 incl GST Quote Share this post Link to post Share on other sites
whterice 0 Report post Posted January 30, 2011 Just about any machine or wheel shop should be able to do it or at least point you to the place that will. As for cost it shouldnt cost you that much. Even if they are larger hub size just switch to lug studs and use standard lug nuts. It will then switch your wheels to lug centric vs hub centric. Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted January 31, 2011 Just about any machine or wheel shop should be able to do it or at least point you to the place that will. As for cost it shouldnt cost you that much. Even if they are larger hub size just switch to lug studs and use standard lug nuts. It will then switch your wheels to lug centric vs hub centric. ALL wheels should be hubcentric and not rely onthe studs tocarry weight. Tristan... go to Wheelfixit, they do all of our work and they have a very very expensive fandangly computer controlled machine which they will use to bore out the wheels. Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted February 1, 2011 Gave them a call and will have them do it if I get the wheels. Cheers Johno Quote Share this post Link to post Share on other sites
Smac01 12 Report post Posted February 1, 2011 What sort of price out of interest Tristan? Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted February 1, 2011 He said around $100-150 to get wheels bored but I'll probably get some kerbing repair and painting too Quote Share this post Link to post Share on other sites
