beeeamer
time for oil change
My 323i is a bit overdue for a service, i'm just not sure what oil I should use becuase there's so much conflicting info out there.
Car has done 195k and runs great, no leaks. I think from memory JG used magnatec 10w40 last time, should I stick with this, change to synth maybe?
any help appreciated
Swapping oil types all the time is not a good thing to do. Mag 10w40 is fine...if it was used last time... stick with it
