nzhaystack 0 Report post Posted February 23, 2011 After some searching around i found a gearbox. Current one has the following stamping on it as follows: GETRAG: 260.0.1346.90 One i picked up today has the following stamping on it GETRAG: 240.0.0132.90 - 225 - 1.1 - 1 They box's themselves look the same however the shifter + linkage is different. Need to know s if the getrag 240 will work in my car that currently has a 260 in it? Cheers Mitchell Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted February 23, 2011 different lengths , also older ones have the crappy steel shifter mech not the ali type. also check the output flange Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted February 23, 2011 Hi Mitchell, Brent has just pointed out to you some differences I remember a while ago telling you to get a 260, basically to change like for like to make that 240 work you will need extra parts Driveshaft, possible linkage, depending on what was provided you can give me a call, as I'm not always near the computer cheers Jon Quote Share this post Link to post Share on other sites
