jksnz 0 Report post Posted February 28, 2011 I have a E46 328i - 2000 model that is making a high pitched squeeling noise when running. So far - belt tension kit replaced, intake system checked and parts replaced, brakes checked by Claytons in Takapuna. high pitched noise, does not change in volume or pitch when in motion or under acceleration. Think of a the noise you get then spinning metal on a lathe and cutting the metal (hope it makes sense) I noticed it happens when it hot outside and I run the air con.. Any thoughts...Claytons are struggling to get it resolved and the noise is driving me crazy... thanks Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted February 28, 2011 was the ac tensioner replaced? Quote Share this post Link to post Share on other sites
jksnz 0 Report post Posted February 28, 2011 was the ac tensioner replaced?will check with them, not sure at the moment Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted February 28, 2011 if it only happens when the aircon is switched on then its likely that it is either the aircon tensioner as above or perhaps the aircon pump bearings or clutch unit.. Quote Share this post Link to post Share on other sites
jksnz 0 Report post Posted March 2, 2011 if it only happens when the aircon is switched on then its likely that it is either the aircon tensioner as above or perhaps the aircon pump bearings or clutch unit..they havent replaced the aircon tensioner, so will check whn the car is back with them next week. Trust my luck it has stopped making the noise now. Will keep update as soonthanks for your input. Quote Share this post Link to post Share on other sites
