Jamex316
2001 E39 TV in motion
Anyone knows how to change the settings so the tv stays on while the car is in motion?
I've tried the ignition, tv contract/brightness etc etc. Didn't work.
And also, where is the obd connection?
What year is your car? - Dictates the method.
Cars with second generation video modules (09/98 >) require coding to enable. Previous can be done by method you mention. I can help if you wish - PM me
OBD connection - again depending on year >2000 are round pin OBD plug under the bonnet. Post 2000 are OBD2 inside the car
Edit: Sorry - just woken up :rolleyes: Your car is 01
Edited by hotwire
OBD - Drivers side up in the little cubby box thing by your right knee. Has a cover that pulls off
TV in Motion seems to be programming - Im just about to do my 2001 525
How will you program the tv in motion bit?
Needs doing as I have described to you - with the correct software
Im planing on using the NavCoder software. I have wired a permenant RS232 adapter into the car on the IBUS.
Have ordered Navcoder online and payed for it with Paypal - Just waaaaiting for Jochen to check his email and send me the access code.
