MNZ 0 Report post Posted March 5, 2011 (edited) Hi Guys, I am bringing in some Wotbox's from USA. To keep it all honest I am selling these with a slight margin only to cover the one that I am bringing in for myself. I have ten available and 4 of them are already spoken for so be quick. They are not vehicle specific so will work on most vehicles, simply requires a clutch switch for activation and everything else will already be in your car. Details: To explain the WOT box in short: 2-Step Launch Control: modulates the ignition by cutting power to individual ignition coils to hold the RPM you want to launch at. The Turbo will then spool up a bit, and you can launch while already in boost! No-Lift Shifting(WOT Shifting): makes no-lift shifting easy by cutting your engine's ignition for a very short period while you no-lift shift. No-lift shifting is when you have your foot to the floor in any gear, push the clutch in to shift, while keeping you foot on the gas. The ignition cut allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. Keeping your foot down through the shift also allows you to hold boost through the shift, thereby significantly improving your E.T. Mk5 GTi Launch control On a Mazda 3 but listen to 1st to 2nd change, no lag coming back on throttle at all. These can be used on cars without turbos too with benefits so don't think they are just for turbo cars. Any questions just ask or PM me. Price is $260 per unit! They are $189USD + Freight from USA which is around $280 right now. Comes with serial to USB converter to adjust settings of unit for shift times and rev limits etc, all user programmable. Edited March 5, 2011 by MNZ Quote Share this post Link to post Share on other sites
