pureboiracer 0 Report post Posted March 22, 2011 (edited) Hey guys, have some gear out of my race car for sale m20b25 engine, rebuilt back to factory specs by me has done approx 20k since rebuild, rebuild consisted of new rings, bearings, decked block, crack tested crank weighed pistons rods etc, was all so close there was no need to balance it, new valve springs, rockers, valves, valve seats, 272 fast street cam. computer is chipped and runs 7k rpm all day running motronic 1.3 car dynod at 108kw atw. dont have recipts for rebuild or for dyno cost me $3500 in parts just for rebuild motor $1500 exhaust system with wayneys headers, going into a 2 1/4" system. $500 getrag 240 box, all in working order. i have never opened the box but it still works fine, also comes with a 6kg balanced flywheel and a unsprung 5puk clutch and heavy duty clutch clamping cover. $250 for just box $350 with clutch and flywheel also have a 4.1 ratio med case e30 lsd, in good condition no oil leaks, diff has been apart and checked over. still standard lock up. $800 you all know what these bits look like so i havent put up any pictures. if you want more info message me cheers oli Edited March 23, 2011 by -Oli- Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 24, 2011 ok gearbox and clutch is sold, will also note at this point front camber/caster adjustable plates for an e30 $270 cheers Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 24, 2011 Dammit wanted the clutch and flywheel. Still have the flywheel or did that go too? Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted March 24, 2011 Pics and condition of camber plates? How old are they or any idea of milage? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 25, 2011 Theyre still in car at the moment, will get some pics this w.e. They are still in perfect working condition. Not sure of age or milage as I didn't buy them new Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 25, 2011 Dammit wanted the clutch and flywheel. Still have the flywheel or did that go too? Clutch and f.w gone, buy diff instead;) Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 25, 2011 Andrew, the camber plates came out of my green E30, I couldn't tell you how old they are either sorry. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted March 25, 2011 Clutch and f.w gone, buy diff instead;) haha we already have the same diff Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 28, 2011 couldnt get a good pic of the c.plates in the car but heres a link to an image of the same style plate. http://img360.imageshack.us/i/picture16522373.jpg/ Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted March 28, 2011 Random Trade suggestion time: If anyone wants a 3.64LSD, they can buy Oli's here and trade me the 4.1 for the 3.64. Who knows, maybe someone needs a longer ratio! Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted March 28, 2011 Ah so keen on diff. Swap for my locker. bro. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 28, 2011 ^ just buy it. you know you want to.... not many 4.1 lsd's around Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 1, 2011 gearbox, clutch and camber plates are on hold. Bump for the rest. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 6, 2011 bumpskies. motor, exhaust and diff to go.... Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted April 15, 2011 (edited) bumpskies, more details on the engine now i have time to write it out properly, it has new: valves valve springs rockers seals/gaskets 272 schrick cam big end , main, cam bearings piston rings frost plugs 3 face valve seats pistons and rods have been tested and weighed, crank has been tested and balance checked. decked block, plained head Piston bores have been re honed, crank journals resurfaced, Iridium spark plugs reset airflow meter new water pump, cam belt, tensioner, etc. comes with intake manifold, injectors, throttle body. also includes heavily modified engine loom and motronic 1.3 ecu with chip. has done approx 20k since rebuild, i have ran it for 2 seasons in my race car but they were only short races so equivilent wear to one e30 series or similar. Theres probably more i have forgotten to add. just pm me for more details. dyno power run was taken when motor was running poorly due to worn ignition components. Edited April 15, 2011 by -Oli- Quote Share this post Link to post Share on other sites
