cliffdunedin 8 Report post Posted March 24, 2011 Hey guys, first decent day we have had down here in ages so put down the windows, trouble is the left rear won't go back up any ideas please guys!? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted March 24, 2011 Hey guys, first decent day we have had down here in ages so put down the windows, trouble is the left rear won't go back up any ideas please guys!? Switch, relay? tried putting it up from the door itself instead of the center console? try putting another switch in the hole? maybe test the switch for electricity with a meter/lamp. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted March 24, 2011 Switch, relay? tried putting it up from the door itself instead of the center console? try putting another switch in the hole? maybe test the switch for electricity with a meter/lamp. Yeah I was thinking either broken switch or regulator! The window went down with both window and console switch, but not up...so was thinking it might be a common prob that someone would know Though will pull it too bits in the weekend and check it out. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted March 24, 2011 switches often fail (worn contacts inside) try using the door window switch . swap left switch for right side switch etc Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted March 24, 2011 Thanks Brent, will try that on the weekend! Doesn't sound like a regulator to you? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 24, 2011 Thanks Brent, will try that on the weekend! Doesn't sound like a regulator to you? have you tried giving the window a little help,be careful of de fingers! Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted March 24, 2011 Yeah i have cheers. I thought the same, might be a bit sticky/weathered Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted March 27, 2011 Had a look this morn and it was a worn connector on the door switch and broken centre console switch.thanks for the help guys. Quote Share this post Link to post Share on other sites
