mc5555 0 Report post Posted May 1, 2005 Has anyone had to go and get a new one? My ones broken so needin a new one. Quote Share this post Link to post Share on other sites
2002 1 Report post Posted May 2, 2005 I had to replace mine, but only because the fuel sender unit which is part of the pump failed. I brought the replacement pump from Autohausaz ( I've got quite a few parts from them both for the e36 & the 2002 and have been very happy with the service. The pump's quite easy to replace, the only trick is making up a tool to undo the locking ring Quote Share this post Link to post Share on other sites
mc5555 0 Report post Posted May 12, 2005 got a second hand one for 80 dollers from german auto after european autospares sent me a broken fuel sender unit with pump. dont really need the tool, just got a long screwdriver and a hamer and knocked it loose. Quote Share this post Link to post Share on other sites
2002 1 Report post Posted May 13, 2005 I'm pleased it worked out for you - I was temped to do the screw driver trick too, but was worried the ring would break before it came loose - It only took a couple of minutes to make something up Cheers Craig Quote Share this post Link to post Share on other sites
