mc5555
Fuel Pump
I had to replace mine, but only because the fuel sender unit which is part
of the pump failed. I brought the replacement pump from Autohausaz ( I've got quite a few parts from them both for the e36 & the 2002 and have been very happy with the service. The pump's quite easy to replace, the only trick is making up a tool to undo the
locking ring
got a second hand one for 80 dollers from german auto after european autospares sent me a broken fuel sender unit with pump.
dont really need the tool, just got a long screwdriver and a hamer and knocked it loose.
I'm pleased it worked out for you - I was temped to do the screw driver trick too, but was worried the ring would break before it came loose - It only took a couple of minutes to make something up
Craig
