nordschleife 0 Report post Posted March 31, 2011 A friend of mine has just bought a 2002 Cooper S. We are keen to do use Navcoder and scan each of the modules. I have the resler interface in my M5 where I use the CD changer connector to connect to the ibus. The Mini does not have a CD changer and if it is pre-wired, the wiring is not obvious. Where is the best / easiest place to connect? Thanks in advance. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 31, 2011 Can't help Matt but I too am curious on that one. Have only had a brief play with a Mini - sorting a nav disc for an ex UK one. Even the nav unit is hidden under panels under the drivers seat & not easily accessable. Has it got TV - video module? If no nav - behind the radio:- Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted March 31, 2011 Look at the WDS, see what devices have the ibus, decide which device is easiest to access-..... If you don't want to watch the ibus traffic, consider just using the dbus on the obdii connector Quote Share this post Link to post Share on other sites
nordschleife 0 Report post Posted April 1, 2011 Thanks guys. Going to give it a bit of a service today. WDS never seems to work properly for me. Will try via OBD and report back. It's NZ new so no TV / Nav etc. Quote Share this post Link to post Share on other sites
nordschleife 0 Report post Posted April 6, 2011 Couldn't get OBD working on the Mini - works great on the M5 though. Next issue is that the WDS navigation works on the left hand side but the image / diagram doesn't show on the right. Has anyone managed to get it workong on IE 9 Windows 7? Once I've got that working I'll connect up to ibus. Cheers Matt Quote Share this post Link to post Share on other sites
Dogballs 124 Report post Posted April 11, 2011 (edited) Couldn't get OBD working on the Mini - works great on the M5 though. Next issue is that the WDS navigation works on the left hand side but the image / diagram doesn't show on the right. Has anyone managed to get it workong on IE 9 Windows 7? Once I've got that working I'll connect up to ibus. Cheers Matt Hi Matt, try this site, seems to work better than the other one.. http://www.bmw-planet.com/diagrams/release/en/ Make sure that Java software is updated on your pc.. Dean Edited April 11, 2011 by Dogballs Quote Share this post Link to post Share on other sites
