sp8s 1 Report post Posted March 31, 2011 How do you or even if you can ID a gearbox. Got a ZF cheap but dont know what it came out of. Its an overdrive version. I know there are markings on it to say what it is and the ratios but not what it came out of. Was told it came out of a 525 early 90's. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 31, 2011 put up a pic of it incl the numbers on it , and yes early e34 M50 525i had the overdrive ZF box Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted March 31, 2011 pics As you should be able to see typ s5-16 stuecklisten - nr 1048 000 getriebe - nr ubersetzunge 3.716, 2.037, 1.339, 1.00, 0.8, -3.543 oelmenge 1.115L seperate number 31.5035.00 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 1, 2011 hope you didn't pay much for that . it looks like its from a e28 1984 520i m20 engine very early anyway with that type of gear shifter mech is the distance between the top 2 bolt holes about 140mm then its a m20 type box if its 120mm then its a m30 m10 type box maybe a e28 525i 528i 1984 m30 http://bmwfans.info/parts/catalog/E28/Seda...manual_gearbox/ Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted April 1, 2011 Thanks Brent Appreciate the imput Quote Share this post Link to post Share on other sites
