sp8s
gearbox id
How do you or even if you can ID a gearbox.
Got a ZF cheap but dont know what it came out of. Its an overdrive version. I know there are markings on it to say what it is and the ratios but not what it came out of. Was told it came out of a 525 early 90's.
put up a pic of it incl the numbers on it , and yes early e34 M50 525i had the overdrive ZF box
pics
As you should be able to see
typ s5-16
stuecklisten - nr
1048 000
getriebe - nr
ubersetzunge 3.716, 2.037, 1.339, 1.00, 0.8, -3.543
oelmenge 1.115L
seperate number 31.5035.00
hope you didn't pay much for that .
it looks like its from a e28 1984 520i m20 engine
very early anyway with that type of gear shifter mech
is the distance between the top 2 bolt holes about 140mm then its a m20 type box
if its 120mm then its a m30 m10 type box
maybe a e28 525i 528i 1984 m30
http://bmwfans.info/parts/catalog/E28/Seda...manual_gearbox/
