nickchin1308 0 Report post Posted April 11, 2011 The washer jet doesnt work when I try use it. How much will this cost approx? Cheers Nick Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted April 12, 2011 Both E39's I have owned failed in this area. In both cases it was the motor - easy enough to swap out. Get someone to operate the switch while you listen and/or feel the motor to see if it has seized. Depending on year, the motor from the intensive clean is the same, so you can swap and loose the intensove clean for a free repair, or buy a new motor. From memory, new motor from Jeff Grays was around $100, you can probably do better from some of the parts guys on here. Quote Share this post Link to post Share on other sites
HELLBM 1669 Report post Posted April 12, 2011 Can do a washer motor for you. Quote Share this post Link to post Share on other sites
