Greg111 13 Report post Posted April 20, 2011 Worth a shot, sounds like you have a we gremlin somewhere, auto sparky me thinks, hard to diagnos properly without seeing it. Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted April 20, 2011 Greg. said: Worth a shot, sounds like you have a we gremlin somewhere, auto sparky me thinks, hard to diagnos properly without seeing it.Yea, its a prick of a problem. More annoying than anything. Tried wiring my headunit to the lighter and get the same issue. Could be anything from the sender behind the cluster to a sensor or grounds etc. Havent had a look at the sensor yet. Could be that too with all of the speed orientated calulations out. Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted April 20, 2011 Have you had a look at the dignostic functions of the obc? Might help pinpointing the problem Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted April 20, 2011 You mean the locked functions on the OBC? I have unlocked it and had a play. Everything seems to be working okay. Unless there is something else? Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted April 22, 2011 So I resolved the problem. Turns out it was the ignition wire into the headunit. Once I hardwired this so the Headunit is constantly on ( without the key in ) my OBC started working perfectly. The feed from the ignition must have drawn to much current and turning my headunit off when driving :S Quote Share this post Link to post Share on other sites
