_Matt_ 42 Report post Posted August 11, 2011 (edited) after a month or so of sweet beats I took the enclosure out to get to my suspension struts. I got Lazy when installing it again and didn't disconnect the battery. so + met - and pop. I saw the amp fuses flash so i checked them but they are OK, I checked the fuses in the engine bay and they are OK. the head unit reset itself and both that and my amp/sub woofer still run. Problem is I have minimal control over my amp now from the head unit. I can set the level of base but can't set base gain, frequency, I cant even turn it on or off. Can anyone help? Edit: I just remembered I have one pair of RCAs plugged into the sub out and another into the front pre-outs. So I may have plugged the wrong set into my amp. Ill test soon haha. Edit 2: Yip, fixed. Good one Matt Edited August 11, 2011 by _Matt_ Quote Share this post Link to post Share on other sites
Gaz 1069 Report post Posted August 11, 2011 Looks good Matt. You still in Hastings Street? If you are next time I'm at my mates I'll swing by. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted August 11, 2011 Looks good Matt. You still in Hastings Street? If you are next time I'm at my mates I'll swing by. Na Bro, moved in Jan. In Burnside now Quote Share this post Link to post Share on other sites
