pureboiracer 0 Report post Posted May 8, 2011 Hey guys, need to get another master cylinder for my race car. The one that came out was from a 7 series so i dont know what size one should go back in. The car is a pfl coupe with disc rear and no abs. As far as im aware there is about 3 or 4 different piston size setups. Anyone help? Cheers oli Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted May 8, 2011 Just double check the race regs mate, I think there is something in there about which cylinder and booster is to be used. I have a couple in the garage which may be suitable - would do with a re-seal and hone though. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 9, 2011 There is nothing in the rules which dictates the part number of the master cylinder, so long as it is standard factory equipment. Can anyone help out here? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted May 10, 2011 9 – BRAKES 9.1 Required Equipment: a) The braking system shall be standard Original BMW equipment, as fitted to either 318i or 320i, including master cylinder(s), brake booster(s), metal brake lines and brake callipers. From Realoem for pre-fl 320i coupe: Brake master cylinder 19,05/20,64MM ? 34311154263 Brake master cylinder 19,05/20,64MM ? 34311156273 Brake servo unit ATE 1 34331157416 Stop being a lazy-arse Quote Share this post Link to post Share on other sites
