Nate
o2 Sensor?
dealer
Forget that.
600 bucks for a five minute job with a 150 dollar part?
No thanks.
If you want minimal hassel - dealers
I've read that you can use a normal O2 sensor (maybe from Jap brand cars as long as they are OBD I or II whatever you car is currently), chop the connector off, solder the connector from the old sensor and reuse.
BMW sensors cost upwards of $150+, standard sensor is probably 1/3 cheaper. All that it is difference is the connector.
Hope that helps.
Forget that.
No thanks.
Thats what I mean, buy the part from the dealer and then install it yourself. How hard can it be its only a sensor.
Forget that.
No thanks.
No no - thats 600 for the sensor - not the installation :blink:
Forget that.
No thanks.
Bloody hell, I'd look elsewhere too. Forget my Dealer suggestion....
Grant
