curryinahurry
E46 Windscreen Demister Stuck on Hot
Hey guys, I was driving home yesterday, and turned on the demister to clear the fog on my windscreen.
But I noticed it was blowing out hot air, even though I have the Air cond on, and the temperature set to the lowest (16°C). Is this normal?
It blows out cold air as it should when I set the blower to blow out the front / foot well vents...
Cheers,
Andrew
Did you mean the button with icon that's fan-shape with 3 arrows going up (top right corner)? Pretty sure that's normal. Whenever you use that button, it automatically set to max fan-speed and max-temp, air-con on with fresh air (not recirculate) to clear to fog in shortest time. It does this regardless of what you've set just before pressing the button.
Yep, thats the one.
Hm, its interesting - I've had the car for a couple of year, but its the first time I noticed it...
I tried it again yesterday, but I think its back to "normal" - i.e, it blows out cold air when I tell it to. Quite strange...
