Pacamacs 0 Report post Posted May 29, 2011 Hi Guys, looking for some ideas. Have a 2003 540i m spec and have just done a thousand km in a couple of days and when i arrived home and shut off the car and removed the key the head up display and monitor are still live, car radio still playing and it wont lock with the key. Seems like it might have a power relay jammed on somewhere, disconnected the battery and left for a while but still the same when reconnected. Any suggestions? Cheers Imac Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 29, 2011 If the climate air and cigarette lighters work, I'd be checking power supply at the ignition switch. With ignition off, key out, the violet wire on the ignition switch should not be live. Quote Share this post Link to post Share on other sites
