miketonny 0 Report post Posted May 30, 2011 Hi guys, I have a BMW 525i E39 2002. Early this morning when i drive to work i noticed the "Check Coolant Level" light was on. I googled a little to try to see if that's serious, and saw posts saying it's easy to check it myself, but as I'm newbie to mechanics, how exactly do i need to do to check it? and if it turns out I need to replace something, is there some articles or blogs can read? TIA for any advices. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 30, 2011 (edited) lift bonnet ,when engine is cold , undo the coolant tank cap (radiator cap) check if the coolant is near the top , if not top it up. but you may just have a faulty coolant level sensor or worse a leak somewhere , get it checked befor you cook your engine , dont drive it if its leaking as it will over heat !!!!! Edited May 30, 2011 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
miketonny 0 Report post Posted June 2, 2011 lift bonnet ,when engine is cold , undo the coolant tank cap (radiator cap) check if the coolant is near the top , if not top it up. but you may just have a faulty coolant level sensor or worse a leak somewhere , get it checked befor you cook your engine , dont drive it if its leaking as it will over heat !!!!! thanks I checked it 2 days ago the red stick was low, but the warning only showed up once on monday and never did again. so yesterday i added water in there to test if it's leaking . after driving for a day the stick looks fine on the level. so it's not leaking either. I was told by a workshop guy I need to put 50/50 coolant/water in there and it's better to use BMW original coolant that right? how much would this normally cost though? Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted June 2, 2011 thanks I checked it 2 days ago the red stick was low, but the warning only showed up once on monday and never did again. so yesterday i added water in there to test if it's leaking . after driving for a day the stick looks fine on the level. so it's not leaking either. I was told by a workshop guy I need to put 50/50 coolant/water in there and it's better to use BMW original coolant that right? how much would this normally cost though? The last lot I got from Team McMillan was around $14 for 2 litres I think. Quote Share this post Link to post Share on other sites
miketonny 0 Report post Posted June 3, 2011 ah damn thats cheap if i want to do it myself just make sure it's 50/50? got any idea how many liters in total i needed? Quote Share this post Link to post Share on other sites
